1 - 2 of 2 Posts
ok here the deal i recencenty bought a 99 9-3 convertible from the auction, the top is not working from the switch. i removed the motor to see if that was the problem. i took the little circuit board ring off the motor and tried to apply power directly to the motor and it worked top still did not move. there is know power in the switch i am a mechanic so i checked the regular fuses ect and they were all fine. i tried to manully retract the roof like the owners manual says but it seem like the locks on the fifth bow are not releasing to lift the tanauuo cover. i did notice that the pin in the u-joint had sheared into 3 peices so i replaced it. the pixels in the display center are not working properlly so i am not really sure what it is sayin but i do know that when i hit the roof switch it chimes. at this point i do not really know where to go from here. if possible can some on e tell me in detail how the system works or have any suggestion on what the problem migt be
1 - 2 of 2 Posts
