99 9-3 Convertible. Cabin fan has quit working entirely. I went to check the fuse, and there is no fuse in the slot that is marked Cabin Fan/ACC. I put a fuse in and it made no difference. I have relaced the AC/Heater module before (myself) due to the crummy knobs that so many people have had problems with, but that was over a year ago. So, can anyone help me troubleshoot if this might be a problem with the actual fan or just with the module, or something else?
Thanks!
Fuse 3 is for Manual climate control heater fan, fuse box on the drivers side dash.
The only 2 things other than that is the fan itself, or the control panel,..
I'm assuming this is a Manual Climate control right?
There is a ground also. G33P located on the LH lower A-pillar. (basiclly under the fuse box) on the fwd door jamb under the covering....... might want to take a peek at that too.
Whew!! One more thing (I feel like Columbo),... There is the resistor pack under the fresh air filter Lh side. Might be that,...its wired in paralell so its more likely to fail at one or more speeds.
I.E..speed 1 doesnt work but 2,3, and 4 do.
or 1 & 2 dosent work but 3 & 4 do. ect....
