Car: 97 9000 Aero, w SRS on passenger side.
The following are fairly comprehensive directions and comments to change a relay in a 97 Saab 9000 Aero.
In this case a Turn Signal Relay - the right blinker was not working.
The relay is located with others on the passenger side, under the SRS, behind the fuse array.
There’s a plastic/upholstered cover (cowling) over the fuse array that must be removed first. It requires some force and should be pulled out as straight as possible or some fuses may fly.
I had been under the impression that it was fastened, it is not, it simply clicks in and out of position.
The following shows in detail, how to remove the fuse array to get to the relays?
