My 96 SE V6 (109K miles) runs great unless I go more than 100 total miles on the highway. It starts hesitating, then the check engine light starts flashing and it dies out, leaving me at the side of the road. When I try to restart, it will fire up then die immediately, with the red ! and CEL coming on. I get it towed home, then it starts up and runs fine again until the next long highway drive. What's strange is that it only happens after I drive 60 miles or so, park it for an hour or two, then get about halfway home on the highway when it dies.
I've read other posts which describe a similar problem. The closest diagnosis seems to be a crack in the fuel pump diaphragm. The fact that it happens the way it does, and that it starts and runs again after a rest period seem to rule out other possible causes. I don't have access to any testing tools or a garage, are there any simple things I can check to confirm this? And if this is indeed the case, what is the procedure for changing the fuel pump on this specific model? I hope it's not too tough or eeks-pensive. Thanks!
