If you are having a problem with the front wiper fuse blowing on your NG900 check your backup light switch located on the tranny (drivers side located just about under the master cylinder). Remove the connection and see if the fuse still blows...if it does thats the culprit. I thought I'd share this because it took the whole day for me to track it down and it doesn't seem very obvious untill you check the wiring diagrams (the wipers share the same juice as the back up lights...go figure?) I didn't even know my back up lights were down...I discovered the wipers were down in a rainstorm
