I read somewhere, sometime, that a good upgrade was to use the 2002 95 aero rear discs and calipers to upgrade the rear brakes of a 93. I also think I saw something like that in GenuineSa, but I do not find it anymore, though. ;oops:
Do I need any other parts apart from the caliper and disc?
As per the EPC, the rear discs are 288mm in diameter and 20mm thick, I believe htey are ventilated, as the front.
Thank you for any guidance.. ;)
Rear Aero discs you want are 300mm...
Look for the discs/calipers from the 02-04 Aero and 02 V6 Vector
You'll also want to pick up the stainless brake lines that fit between the new calipers and the hard lines. GenuineSaab carries those....
Sorry to completely whore this thread, but if I'm upgrading my calipers, rotors, and pads to EBC Greenstuff will I need new brake lines as well?
The new rear brake lines are used because the 9-5 Aero style caliper moves back and forth. The stock lines wouln't quite work.
If you are not upgrading your calipers, then the stock lines will be sufficient.
