1 - 8 of 8 Posts
Does anyone know if this can be reset without going to a dealer ? I pulled the fuse while it was running & set it off
Dealer is your only option. You can post/look on the Tech 2 forum on this site to see if someone in your area with one can help.
If you can get an SRS unit (the one under the console) from an NG900 that doesn't have any codes set, you can swap it in. It's a crap shoot if the car is in the u-pull, but your odds are fairly good if it doesn't have any air bags deployed and the seat belts still work. 1995 splits the convertible and 3d/5d... later years don't. I don't know if that matters i.e. if you could use a unit from a later year and have it work.
Probably easier for '95 just to find a Tech II.
Anyone know if one from a 01 9-3 could possibly work, I have a parts car
1 - 8 of 8 Posts
