Im not agreeing or disaggreeing with the opinions on suspension but The springs and shox depreciation is an interesting issue, and maybe this post is a good place to start to really look at whats happening with the depreciation in a technical sense.
I had 2 alfa romeos , also quite heavy cars at 1475 - 1575kg and they were on original suspension at 134000 miles and 110000 miles respectfully, and both of them held the road like glue, and still felt very tight to drive.
I off course drive mostly on my own with little baggage, and im very particular about going over any obvious bumps on the road - speedbumps, ramps etc very slowly as i like to treat my car very well, but i also like to use the suspension when required in the corners.
But im not saying the saabs suspension does or does not need replacing at the miles suggested but i would certainly like to find a way of determining when the rear springs or front shox / springs are past it as i would like to maximise my suspension status but without replacing things unless necessary.
I have changed my rear shox as there was a leak in one of them, and this made a difference especially noticeable in improved braking
But how do i determine if my rear springs or front shox or front springs are past it.
I assume that the quality of manufacturing will have a bearing on the depreciation ?
Can anyone scientifically describe the process of wear on the saab shox and springs ?
Is there a way to determine this state of wear ? - progressive, or sudden etc and how progressive
Or do you just change them after a certain mileage as a precautionary undertaking to ensure you now have excellent suspension
I have heard so many opposing opinions of how long shox and springs last, that it will be good to put some objective data on the board
