1 - 20 of 64 Posts
Hey all,
Just bought a 1989 9000 2.0 Turbo auto, with broken timing chain.
picking it up in 2 days... then the fun begins with swapping the B234R and manual 'box (including removing TCS from the B234R), aero seats, and seeing how much work to change the aero's ACC and dash computers in, along with going to the 17" rims i had on my aero.
possibly swapping front and rear ARB's, and making a piggyback one out of the original rear ARB from the '89.
any other parts i still have left will eventually be fitted, along with some nice new shiny parts.
unfortunately though, i will have to remap my ecu to a stage 1 or even stock (is currently a maptun stage 3) until i can get hold of a new exhaust system. as i will be disabling TCS via T5 suite, will have to re-flash with lower stage tuning :cry:
any input as to any troubles i may run into with this list of things to be done would be appreciated.
thanks in advance!
I'm sure there is an interesting story here..
Sorry, was picking up the new car yesterday, so was unable to reply :)
about 20 months ago, i had a slight accident in the aero.. didnt see a corner (the local council has now erected high visibility corner signs!), and went down an embankment, rolled once, parked in some trees.
all the doors still open on the aero, so the shell held up quite well.
But now, I found a cheap 9000 turbo in good condition, and will customise to my liking.
Ahh, GTlegs, I was actually picking up the car from Melbourne yesterday!
can't wait to get started with the changeover.. the '89 has a broken timing chain, but i happen to have a spare one for that engine laying around, so will be replacing that first, seeing if the engine is fine, then pulling it out. always good to be able to sell a working engine.
also came with a pretty new DI cartridge and working APC solenoid, so this gives me 2 spares for the B234R.
will keep you all posted with photos etc as i go along :)
Nice, just checked it out.
Did I mention that I got a 9000 Griffin the other week? Its gonna have its RWC and the whole front end of the motor replaced next week (to avoid any future hassles with tensioners and cambelts). It drives beautifully (touch wood).
CAMBELTS or timing chains
I thought griffins had 2.3 turbo engines, with timing chains. Or did Saab put out a V6 griffin
Discussion Starter · #15 ·
GTlegs - nice work btw...
I haven't been a real fan of the CD shape, as i tend to fill from boot lid to front seats when i go away, but from what i have read and heard, the griffin is quite a nice car to drive.
on another note - looks like i will be also installing an oil catch can and then doing a 3" air intake pipe, as i just found my 2m of 3" aluminium tubing.
going to visit the 2 cars tomorrow to start a bit of this work.
Discussion Starter · #17 ·
Sunday is the day the aero loses it's subframe and engine.
then comes the fun task of cleaning it up, working out what needs to be ordered, as I am considering doing the timing and balance chains, including all sprockets etc while its out (only done 130,000 kms, but easier while engine out), replacing exhaust manifold studs (1 broken, needs removing), air con compressor mount replacing, and anything else i can see that needs to be done.
will post some pics up soon!
Exactly
justin.graeff said:
Looking forward to some pics. I want to see how all of this goes.
Me too. Will follow this with interest. Yes doing the timing/balance chains, at least checking them while it is out will be easier than when it is in. But from a complete novice on Saabs let me say that doing them in the car is not that hard.
Discussion Starter · #20 ·
well.. here is he work done yesterday...
Engine in the Aero
Aero removed from engine
I did the "remove subframe" trick... so I didnt remove the engine from the car, I removed the car from the engine!!:cheesy:
the rest of the day was filled with removing the aero's dash and body wiring loom, manual gear shift (doing manual conversion to the '89, so need all those parts) and cleaning up the leather steering wheel from the aero so it can go in the '89
1 - 20 of 64 Posts
