1 - 2 of 2 Posts
Hello,
I just completed an engine swap due to a cracked block (2001 Saab 9-5 V6 Turbo). I have double checked all electrical (fuses relays etc.), everything is hooked up, the plugs are all getting good spark.
The fuel injectors are not opening, there is fuel pressure, the pump is working.
The engine starts and runs while spraying starter fluid into the throttle body.
Please help. What else can I check? is there a cut off switch or rollover switch that stops the injectors?
Any help or point in the right direction please.
Thanks, Shane
Discussion Starter · #2 ·
Still not working
I replaced the intake and throttle body with the one from the original engine. Same thing the injectors are not functioning.
Shane
1 - 2 of 2 Posts
