If u wanna add trans fluid or any repair fluid, jus locate plastic plug below brake fluid resvr. Its pull out style plastic screw, ez use 2 fingers apx dime size...;ol;
If it's a classic 900, it should be a metal 19mm? hex headed plug with a dipstick on it.
No plastic plugs on mine that I could see. I will check though....
Maybe the previous owner lost the filler plug.
I agree, if indeed your car is a '94 classic 900. If it's a classic 900, it should be a metal 19mm? hex headed plug with a dipstick on it.
There should not be a plastic plug.
