i just got a 3.2l 900s with 128,000 miles on it that wont idle and would die out if it dropped below about 1200-1300 rpm. i ran a bottle of seafoam thru and the problem changed from dieing out while driving to on the rare occation idleing perfectly. but at the moment, after starting the car it will pretty much die right away unless you gas it so that it revs above about 1000-1100 rpm. this is my first saab so im not sure, but what i thought could be the problem is that the plastic box that connects the intake hose to the throttle body does not have a air tight seal so that confuses the computer(on my car the plastic box just pulgs straight into the throttle body, there are two screw holes at the top of the throttle body that are not used, am i missing a piece that should be sealing the two together?) i attepmted to rig something to seal this and when i get a good seal the car will generally idle but rough and with fluctuations ranging from slight chuging to random high rev spikes. reving the gas generally causes it to die out.
possible Vacuum Leak?- there is a small rubber hose that comes out of the throttle body, the end of it is not plugged into anything, it has a small plastic piece in it but it doesnt seem to fit into anything. coming out of the head is a plastic piece that splits into a Y and has a larger rubber hose on the left and a small hole on the right that i think it should connect to but the pieces dont fit into eachother should i superglue it?(i cant find a picture for reference that shows this hose in the haynes manual)
i read the Guide to curing variable and high idleing as well as seached the posts and but im unfamiliar with all these sensors and its tough trying working on it myself and not being able to check the components with the car idleing because it wont stay running.
the throttle body itself is fairly clean and i cleaned out some buildup out of the hoses coming out from it . im not sure how to check if the o2 sensor needs replaced
(also int the middle of replacing my radiator hose and auxiliary belt the hood latch stopped popping the hood:x anyone know how i can get the hood poped now? )
any help is much appreciated
thanks
thanks
