I was able to secure a pair of the top of the door trims that are not split! Now I need to know the correct procedure for removal and installation. Anyone have a step-by-step process or know where I can find one? Search engines only turn up process for the molding on the side of the doors.
Side bar: What is the correct name for these pieces of trim?
Look for the factory service manuals in the Stickies at the top of the Forum page.
You want the convertible section (8.6?).
Nothing There!
Vert section is 8.5 and covers nearly everything except how to take off the top trim from the door! Augh!
TY! Do I reuse the existing spring clips to install or will they brake in the removal process and so would need new ones?
Also, off thread user said there may be screws at the end of this trim to remove first. True?
