please help lack off power seems like the turbo is not working had a tech 2 check showed up nothing changed mam not much better what else should i check :(
Hard to tell, very hard, in fact.
Is the servicing up to date ?
As a guess, I'd say that your wastegate is stuck open.
Why not try for greater detail, and clarity,such as the actual code , if any ..
How long you been driving a Diesel powered vehicle, Greg ? There is much to become enured to..
Are there any leaks in pipes from turbo to the inlet manifold? Are you getting the check engine light? (probably not, if Tech2 didn't show anything. This also outrules the "limp-home mode", right?)
How about the fuel filter? Bad diesel contains water, which accumulates in filter - try to drain it and look if it's clogged.
ran a bit better after i fitted mam when it got warm then tried to boot it and engine check came on again
