1 - 2 of 2 Posts
The last few weeks, more and more my driver's side door will stick.
I will unlock the door and pull the latch to open the door, but it won't do anything. All the other doors will be fine, and it will open from the inside.
Pulling the latch doesn't seem to release anything, and it feels like I'm just pulling on the door.
What's going on?
chances are very good that the little rod that runs from the handle to the latch itself has come off. Open the door (somehow!) and pull the inner door card - peer into the cavity (you might have to remove the moisture barrier (plastic sheet) if it's still in place - there should be a metal rod running from the handle to the latch - you'll see it if you move the handle (it'll move if still attached to the handle) - hook it all up (you might need to get a new clip that holds the rod fast to the latch) and your door should work as it's supposed to!
1 - 2 of 2 Posts
