I read through so many articles about my wife's SAAB. IE the changing on fan resistor, change of thermo and switch etc etc.
So what I did for a while was I unplugged the left fan and plugged it into the fog light switch plug and just manually controlled it (which worked because of the usual short commutes and relatively cool temps in Seattle). However, we have been needing to drive it in heavier traffic and hotter weather in Seattle and I finally got around to working on it.
I changed the thermo and the thermo switch to a 80C one from the stock 92 that was in there I believe. I flushed the system, which ran very smoothly I may add.
My problem is this, after doing all of this once the car gets warm (only shows about 1/2 below halfway now so thermo must be opening sooner) but anyway, i see smoke/steam coming from near the thermostat and the thermo switch housing (it did this before I did my changes as well). If I kick on the fan manually it must cool it down enough because it stops doing that.
So obviously the thermo and the thermo switch are working better as the gauge says it's cooler but it's still not perfect.
Also, I think there is a seperate thermo switch on the top line that goes from the radiator to the thermostat is that correct? It's inline with the tubing. I have tried shorting the wires out on it like you can do with the one in the radiator which kicks on the first fan. This one does nothing?
Any help would be appreciated.
