1 - 10 of 10 Posts
Hi all this may sound stupid to you experienced blokes. But where are the bolts holding the engine/throttle body cover on a 1997 Saab 900S? Non turbo.
I, for the life of me can't find them!!
Help!!
Help!!
A pic would be beaut.
If you are asking about the big plenum that sits over the throttle body, there is supposed to be a clip down at the back/bottom that clips the plenum to the throttle body. I found it easier to actually remove the top part of the clip by squeezing it out of the plenum, than snapping it loose at the bottom. When it is released, the plenum is lifted from the back and slid backwards to release the front retainers.
If you have removed the plenum without dealing with the clip, it's gone missing. #8 in the diagram.
270911
1 - 10 of 10 Posts
