Hey guys,
So I located a TD04HL turbo in a 93 9000. In the morning I'm planning on finish ripping it out of the car (got at the junk yard 15min before closing) to get it ready to put in my 99 9-3 with AC.
I didn't look at it before I left, but after a short search online the 9000 Intercooler is a cross intercooler, unlike the 9-3's which has the inlet and the out on the same side.
Does anyone know if the 9000 intercooler fits the 9-3 without any mods/cutting? Is it a really a improvement from the stock 9-3 cooler?
Thank you
Search and look up info about the 9-3 Viggen/HOT crossflow intercooler. Direct bolt in and im not sure about the 9000 IC but anything can be made to fit if you want it to
The 9000 intercooler is not a particularly good IC, even compared to the stock double pass IC on the og9-3. Although it has a very large frontal area it is so thin that it is a major restriction on the intake piping. this crossed my mind a long time ago as I had free access to several of them, but I determined it was not worth it
As neilv said, you would be better off checking the yard for the crossflow that came stock on some og9-3s and the viggen.
Don't want to sound like a salesman here, but I do have an extra crossflow from my '99 9-3 that I would be willing to sell for cheap. Shipping might be a bit pricey since its a big part
Hey, thanks for the reply!
I was just thinking while I was there to grab it, but I decided against it since it looked like it might be taller then I could fit without cutting and all the other IC's at the yard were to big, or to much of a pain to grab (not a saab only yard). I do want an IC that is better then stock, but its not high on my priority. I was planning to work on suspension before getting into my turbo, but I just happened to find the turbo without any play for under $100.
