My 900 SE V6 coolant gage needle is not moving up. car warms up reasonably quick. I would like to measure temp sensor resistance but I have no idea where it is on V6 engine. Can someone help me find it?
Look at the gearbox end of the engine; there is a link casting that joins the two cylinder heads, this has some pipes and electrical connections, one of the electrical bits is the feed you need.
Thanks ,
I did the following:
There is one sensor with two 8" long wires leading into "elaborate" black AMP connector, ohmmeter mesured open circuit. The other one, blue in colour, no pigtail wires, connector attached to it with spring clip, measured around 720 ohm.
I assume one with pigtail wires is to be replaced.
