The car is a 1995...I replaced the control arm on the drivers side yesterday and now everything mechanically moves if I manually put the top down but when I use the switch the top will move then suddenly stop but I still hear some sort of motor noise from the trunk..and I also get check latches and check soft top on the sid..it also doesn't lock in the back part of the top when the top is up...any help would be greatly appriciated thanks..
well, the motor and drive for the tonneau cover is in the luggage comp. right side, behind trim panel. a frequent trouble cause.
for latching the fifth bow search for apost by member flyhop.
Thanks a lot.. got it..it was that motor. Screwing everything up. Works perfect now..
