1 - 8 of 8 Posts
My girlfriends 900 Taladega's rev counter goes straight up to 2800 rpm whenever you start the car and sits there, once in a while it will read normally but 99.9% its at 2800.
Anyone had anything similar?
Not I
Give this a try
Check the grounds and connections at the ECU and the DIC.
Electronic Control Unit
Direct Ignition Cassette
I know this thread is old, but I've had the same exact problem for about a year. I used to be able to smack the instrument cluster and it would pop back down, but now, no matter how hard I hit, it just sits as 2800rpm unless I drive the car for over an hour, and then it will usually work normally.
Probably another instrument cluster solder crack.
By now this could be an advertised service in the yellow pages, as most cars use this design..or used to;oops:
Me too!
I too have this exact problem. Right at 2800 from start up to shut off. If I go over bumps it starts to work but usually doesn't 95% of the time. I changed the CPS (crank position sensor ) but it didn't solve the problem. I have not checked the solders yet.
Anyone else with this problem??
Why would it be stuck specifically at 2800 rpm's, perhaps it is there as a default when a ceratin error is occurring with its signal.
I bet that when someone gets this fixed on theirs it will be the same fix for all of us. (i hope):roll:
Ok, so I finally got around to fixing the tach.
Here's what I found wrong :
One of the 4 "posts" of the tachometer "motor" (I'm not sure what you call it" had separated from the PCB board. All that was required was a quick touch with the soldering iron.
I didn't take any pics, but it's pretty straight forward:
1. Remove instrument cluster
2. Remove 6 torx screws from back of cluster
3. Unplug all 5 connections to separate the halves
4. I wish I had taken pictures, but on the PCB board right behind the tach gauge, you should see a soldered post (wire protrusion) that is cracked marked "CIN -" or "CIN +" or "CON -" or "CON +", something like that. It'll make sense when you get to this point. Anyways, touch a hot solder iron to this connector to remelt the solder, you can add some more if you wish.
When I did this, because I wasn't sure what I was looking for, so I took apart the WHOLE thing, which was unnecessary. Now, my turbo gauge isn't working, and I can't get my speedometer needle back on properly. I will mention, that when I fixed mine, I also found a broken connection inside the tach "motor". However, I think I broke the connection while I was taking it apart, so that's why I didn't mention it until now. If the steps above don't work, then you need to take the whole thing apart (the needles just pull straight out) and take a look at the tach "motor" ( I found that one of the windings wasn't connected to one of the posts)
Hope this helps!
1 - 8 of 8 Posts
