I need help with the wiring on a headlight switch for an '87 900T. I need to know which colored wires go to the corresponding pin outs 1-9. I have the following: red, yellow, gray, 2 blacks, green, red/green, white/brown. The red/green & green wires spliced together in the same pin has me thinking the previous seller has this all out of whack... well between that & the fact that once I replaced all the bulbs & had everything working properly for a few mins fuses started popping & I lost most lighting to the cluster lol. Any help would be much appreciated... thank you!
you're an absolute godsend! the previous owner had this completely tore apart @ some point...been a pain sorting through the mess he had & getting everything properly hooked up...but gave me an opportunity to redo the dash & wood fascia, so been well worth it. I thank you so much for info and wish you well with yours.
