21 - 32 of 32 Posts
My ac tensioner pulley broke today. I have a B202L engine and the pulley acts as a tensioner. Can the idler pulley be replaced or do you have to replace the entire bracket?
It’s hard to tell, what broke on it? The entire bracket can be pulled out via 3 torx bolts. The pulley is a separate part held by an adjustment bolt on the backside of that bracket so should be able to replace the pulley on its own.
Discussion Starter #22
Is the pulley a idler pulley ? or does it have a mechanism that allows it to act as a tension.
min your photo you can see the teeth on the bracket, those are adjustment teeth that allow the pulley to move up and down by turning the nut, I believe a 19mm long or deep socket is needed. You may try using brake cleaner to clean some of the crud in the teeth as that may be blocking it from moving or adjusting like mine was
My bracket is currently out of the car, I will take a photo of the front and back sides so you can see how it is assembled since I know it is hard to see the angles while it is assembled.
Discussion Starter #25
Thanks ! I really need that ! It will help me see what I’m dealing with.
Discussion Starter #27
Thanks for the pics ! I have a better understanding of how it functions now. I don’t think that mine has broken. I probably didn’t tighten it correctly when it put everything back together.
Discussion Starter #28
I finally got around to reinstalling the tensioner today. I didn’t need a new one. I didn’t correctly tighten the tensioner when I reinstalled the oil cooler hoses. I have a better understanding of how it works now.
that’s awesome to hear! I’m happy to report my MY88 9K is running relatively well after refreshing turbo and a bunch of other things. Have an electrical gremlin somewhere pulling power when car is off - but running sans oil cooler and have not been having any problems there.
Discussion Starter #30
Good to hear that your 88 is running. I had an electrical draw down like that on a Mercedes that took me awhile to figure out. The car would be off and the alternator would be warm. A diode has gone bad and the alternator was pulling power with the car off.
Wow that's quite a transformation! Looks fantastic. There's something about the 9000 without the later pinched headlamps.
Is that some kind of SAAB yard you have pictured [above] ?
Discussion Starter #32
The car was in lot that had about 80 or more Saabs in it. The owner had to move the cars from the lot.
21 - 32 of 32 Posts
