There is no fluid coming out of the rear windshield wiper when the button is pushed. Has anyone had this problem and found a resolution for it? Could there be air in the lines from the resevoir? I have held the button down for a long time to no avail.
I do have plenty of fluid in the tank and the front nozzles spray fluid just fine. i could not find anything using the search.
Un Clog
Try removing the black plastic cover that has the two nozzles on either side. It should flip out-ward.
There is a large metal nozzle there that was blocked on mine. took a pin to it and it worked great after that.
Edit - my search found this post in a related thread: http://www.saabcentral.com/forums/showpost.php?p=937129&postcount=6
Mine had the exact same problem. Just clean it out and it should be fine. I think the nozzels are prone to blockage.
Thanks guys. I cleaned it out the best I coiuld with a wire but it it just trickles out of the main nozzle. I may pull the entire wiper arm out to see how the hose looks.
If not it may be the pump.
Before you take everything apart, try removing the nozzle and activating the window sprayer. If everything works it is probably the nozzle. Get a new one and put it in.
