I am on an island, with no easily parts to get and the car is on the side of the road stranded, not at my house, and its raining :-( Besides that I have another car and trying to understand is a hobby too. The CPS has all signs of being well ( RPM moves, ohms correct) So with the question if it should build op fuelpressure at valve even if CPS is dead, if the answer is yes I know its the fuelpump, as for sure I don't have pressure there without cracking.You could have replaced the CPS numerous times by now, why are you reluctant to do so?
It's a relatively cheap part and a very easy job.
If there are Saabs there you must be able to get parts, what would a CPS cost and what is the car worth?I am on an island, with no easily parts to get and the car is on the side of the road
On top of the throttle body. Either I took off the black plastic hose or I opened the not used vacuum connection with red ring, also right on top of throttle body.Then sprayed 3-4 seconds.startWhere are you spraying starter fluid?
On the surface, this sounds like a failed fuel pump. However, as I mentioned before this is not conclusive. If the check valves on the fuel pump are not working it's definitely possible you would lose rail pressure before releasing the Schrader valve. If you have a fuel pressure gauge attached, while the pump is running, you will know for 100% certainty if you have fuel pressure.Hi thanks for all advice, I realize I am not going the quickest road for some, I am not that much in a hurry, and in the end I will get my parts.
Today I 've put a test light on the fuse for fuel pump. It gets power when turning the ignition on, then goes off. Then when crancking it goes on again; CPS seems to do it's job. Then putted a 12v direct from battery to this fuse as one of you suggested; the pump is hearably working but when pushing the valve at rail right after doing that; still no pressure; So bad fuel pump or clogged filter. The only thing I don't get; why doesn't it fire up after spraying starting spray?
This may not work... you want to spray after the throttle body ... like into the vacuum tree on the intake manifold.On top of the throttle body. Either I took off the black plastic hose or I opened the not used vacuum connection with red ring, also right on top of throttle body.Then sprayed 3-4 seconds.
startCan you post a video with sound of it cranking?
Hi yes you are right, a fuel pressure gauge would be quicker, I'll start it tomorrow with a friend while I am depressing the valve to rule that out, thanks. checking out now noid light.On the surface, this sounds like a failed fuel pump. However, as I mentioned before this is not conclusive. If the check valves on the fuel pump are not working it's definitely possible you would lose rail pressure before releasing the Schrader valve. If you have a fuel pressure gauge attached, while the pump is running, you will know for 100% certainty if you have fuel pressure.
An alternative approach, which I would also not recommend due to extreme fire risk, is to detach the return from the fuel rail (the smaller of the two tubes), slip some fuel-safe hose over the rail, and direct those hose into a container. If you crank the car and gas fills the container, the pump at least somewhat works. Of course, without a fuel pressure gauge you don't know if it's enough.
In any case, it sounds like the CPS is working. I would probably cross that off the list as a suspect. You seem adverse to buying tools, but connecting a noid light to a fuel injector connector would rule it out entirely.
I just hear a lack of battery.Not trying to be an alarmist but….to me, it sounds like there’s something wrong internally.
