Hi all,
My Saab 9-5 lost power during a mile then stalled. What I have done or know is;
- it now cranks but won't start
-swapped DI cassette, no help
-pushed fuel rail valve, no pressure
-had previously "check engine" warnings once in a while, and went off.
-sparkplugs visually look ok.
-sprayed brake cleaner in throttle body then cranked; no result, assuming also no spark.
- see vid; RPM meter moves but I'm not convinced CPS is workingRPM meter
- I read I can test CPS by reading ohm between 2 pins. I assume after disconnecting the connector? Do I need to remove CPS to test it or can leave it where it is?
-any other advice, apart from reading the computer?
Saab 9-5 2002 2.0t automatic
