1 - 9 of 9 Posts
Hi all,
Hair tearing newbie here.:confused: My 9-5 1998 shows classic ACC code 1-14 (Air distribution motor loose). SAAB dealer says "motor needs to be replaced" - at enormous cost... Need to know what to do. Have dismantled glovebox etc but not sure which component I am looking at yet - lots of connectors and plastic visible and Haynes says "remove the unit by disconnecting cables and unscrew". HELP. Any pictures (especially) or advice welcomed
This help you out?
Looks like your part number for a new motor is: 5172580
Should cost you somewhere near: $168.00 :eek:
$151.00 with free shipping from here .
Let's hope it's just loose... :confused:
Thanks for prompt reply and pic. Not too sure 'cos mine's a UK RH drive model and all the ACC stuff is on the LHS passenger side. Guess the part number's the same though.
Yeah everything is just flipped around.
OK - so after unspeakable Aussie gymnastics (I am 65) I found and unbolted the supposedly offending motor. When I tried to check out the ACC error codes I could hear the motor running nicely and making some small stepping noises - but the output shaft moved not a single hairs breadth. So - I am fairly convinced that it has shuffled off it's mortal coil - but in the gearbox part rather than the motor proper. QUESTION: If I buy a motor does it come as an integral part with the little gearbox? I would hate to buy the motor only when I need a new gearbox:evil: . The gearbox is about half an inch thick with the four mounting holes and the motor is attached to it as an integral unit. Any ideas guys??
Magic Magic Magiccccc :D :D :D
Absolutely bang on the button. Gear projected almost 10mm. Tapped it back - reassembled. Bingo! All working - no ACC codes and the windscreen now demists at long last. Many many thanks!!
John Wells
'01 9-5 air-diverter, fixed!
Thanks so much for the above fix - no parts required!
I took my dash off (very easy),
found & removed the motor (very easy),
and pushed the shaft back in (very easy).
Re-installed, I now have a window defroster and warm toes!
Thanks again for the detailed help...
jfenollo
1 - 9 of 9 Posts
