1 - 7 of 7 Posts
have 2011 9-4x 3.0l with a/c not blowing cold enough. verified charge is @ proper level, tried new expansion valve-still not cold, no codes. anyone ever had issues with this sys?
Did you figure out what was wrong with the a/c
my wife has a Saab 2011 94 X in which the air conditioner does not blow cold. I took it to my guy he told me the pressure on the high side was 100 and on the low side was 30. The r34 was at 1.6 pounds.The. compressor for part number for my car is. 13262838 which apparently is the same on the SRX.
There are so few 94x its hard to find information
They don't list a separate table for the 2.8 vs 3.0L. 100 psi for the high side seems too low to me. I dont know what the ambient temp was when you had it checked. I will also say that my personal experience tells me most of these reading in this chart are on the low side, so I would always use the higher of the 2 numbers.
The lower the high side and the higher the low side, the better the system will cool. But you can get too high and too low!
Bottom line is 100 psi for the high side sounds like it has a slightly low charge.
A/C Performance Table
Ambient Temperature
Relative Humidity
Low Side Service Port Pressure
High Side Service Port Pressure
Maximum Left Center Discharge Air Temperature
13-18°C (55-65°F)
0-100%
175-200 kPa (25-30 psi)
500-850 kPa (70-125 psi)
5°C (40°F)
19-24°C (66-75°F)
Less than 40%
175-240 kPa (25-35 psi)
690-1100 kPa (100-160 psi)
5°C (40°F)
Greater than 40%
7°C (45°F)
25-29°C (76-85°F)
Less than 35%
1000-1300 kPa (145-190 psi)
10°C (50°F)
35-60%
1000-1340 kPa (145-195 psi)
10°C (50°F)
Greater than 60%
175-280 kPa (25-40 psi)
1000-1370 kPa (145-200 psi)
10°C (50°F)
30-35°C (86-95°F)
Less than 30%
1240-1590 kPa (180-230 psi)
13°C (55°F)
30-50%
1240-1620 kPa (180-235 psi)
13°C (55°F)
Greater than 50%
1240-1650 kPa (180-240 psi)
13°C (55°F)
36-41°C (96-105°F)
Less than 20%
240-320 kPa (35-45 psi)
1500-1860 kPa (215-270 psi)
15°C (60°F)
20-40%
1500-1900 kPa (215-275 psi)
15°C (60°F)
Greater than 40%
15°C (60°F)
42-46°C (106-115°F)
Less than 20%
280-350 kPa (40-50 psi)
1765-2100 kPa (255-305 psi)
18°C (65°F)
Greater than 20%
18°C (65°F)
47-49°C (116-120°F)
Below 30%
320-380 kPa (45-55 psi)
2000-2240 kPa (290-325 psi)
20°C (70°F)
I appreciate the help but I have to tell you I'm not sure I understand what you mean. I'm at the mechanics gave me the number. I ran on the Cadillac SRX they had problems with the dryer being bad and I'm wondering if this may be the same problem. Do you know if those numbers would make sense with having a faulty dryer.thanks Mike
I understand I didn't mean to confuse you! Yes a failed dryer could definitely cause an issue. Basically the dryer (and I may get some dissenters on this) is just the refrigerant storage device. It has desiccant inside that soaks up liquid, any liquid. So if it was partially full of water due to improper manufacturing or whatever their issue was, it would limit cooling dramatically.
Ac inop
Ok Ive found out they have an issue with the desiccant bag rupturing and the compressors are being torqued down incorrectly. Loosen the compressor bolt and re-torque them. If that doesn't do it replace the dryer. Look for SRX bulletins
1 - 7 of 7 Posts
