1 - 8 of 8 Posts
Got this code today. P2310: ignition coil primary control circuit high.
Wtf does that mean? Any help would be appreciated.
The Saab WIS says there is an issue with ignition coil on cylinder 4. It says to check the wiring harness. Check for cracks or loose connector.
Thanks ill check it out. 4th coil is a brand new one. Think the harness/connection would be hard to change?
Maybe anything else I should check.
Didn't do anything and the code is now gone. Car still shakes under acceleration. Have not been able to make it throw a check engine light though. Yesterday it was saying cylinderr 1misfire but coil and plugs are fine. That code is gone also.
Im so confused
Try pulling off the connector and re-seating it as others have said, could just be a loose connection. Would make sense given that you said they were just replaced. Maybe it just didn't get plugged in all the way?
Had done that yesterday, tried it again right now. I noticed the bolt to the 4th coil was stripped. Is that the ground for it? I have swapped scresws and its now in tight. Will drive in a few minutes and hope all is fine. Stg2 is back in :)
Oh and the wires all look fine, I checked them pretty good in my opinion. Made just they werent caught under the cover either.
1 - 8 of 8 Posts
