Hi
Over the last couple of months I've noticed a noise when starting. Best way to describe it is a sort of metallic "zing". It starts just as the engine catches and lasts for 1-2 seconds max.
Once the noise is gone it doesn't reappear on any startup or while running until the car has been left standing... it only happens when the car is absolutely cold - i.e. after at least 8-10 hours without running.
I thought it might be a starter motor issues but it's definitely coming from the r/h side not the trans side of the block.
Took the serpentine belt off and checked all the pulleys - nothing obvious.
This morning I changed the oil and when I started it back up the noise was there again... slightly quieter but still distinct... and I now think it is coming from the cam cover.
As the oil had been left to drain completely could this possibly be a dodgy cam follower?
The engine has done 120k miles but has always had fully synth 5w/40 and Wynns engine flush used on every change at 5-6k since i bought it at 25k. Lifted the cover off last year and it was very clean inside and the oil always comes out good without crud in it ( although I've not dropped the sump yet)
Any suggestions how I can confirm whether this is the case?
Thanks in advance!
Thanks in advance!
