Hi all recently purchased a Saab 9-3 1.9 TTid
the problem is on the passenger side mirror power folds in, plus the passenger side reverse dip down does not work
on the drivers side the power fold does not fold in neither does the mirror it self move up/down, it does move left to right
I connected my opcom reader to it and it came up with :
driver door module - B1585-06 & B1595-06
Passnger door module - B1585-06
Cannot find any info on them codes but I think they are related to the problem
also I don't know if the previous owner had put a non powerfold or non memory mirror on, as I have the memory seats....?????
Information provided from Saab Workshop Information System
Code b1585 06 and b1895 06
Fault Symptom
No memory function or retraction function for door mirrors but manual function works
On-borad diagnosis
Type of diagnosis
Continuous
Enable criteria:
Ignition ON.
NONE of the following DTCs must be detected:
B1583
Fault criteria:
Fault criteria NOT fulfilled.
System reaction to a fault:
No memory function for door mirrors. Manual still works
Check the writing harness
Move the wiring harness at several spots in several direction to reveal intermittent breaks and short-circuits. Check switches, connectors and crimp connections for oxidisation, retracted pins and pin clamping force.
Diagnosis help
Diagnosis regards:
Electrical fault in connection leads or component.
Functions in the diagnostic tool related to the fault:
Test value:
Mirror Potentiometer Up/Down Driver Door
That information was obtained from WIS, basically it is suggesting that part of your wiring harness maybe damaged or a competent at either end is faulty. WIS is easy enough to find for free online, if you input the codes in it has a process that will walk you through fault testing using a pentameter to test voltages.
