1 - 7 of 7 Posts
im going to install an oil cooler but have a few questions. first what size an fittings would i need to tap into the adapter plate on my 99 saab 9-3 so i can install all new lines and fittings and what size braided hose do i need? also is there anywhere where i could buy a new oil thermostate? does anyone one know what temp the thermostate opens to cool the oil? thanks
thanks for the link. does anyone know if i can put fittings in the adapter plate?what size an fitting would i need and what size line?
http://www.stcf.net/OilCooler/index.html
The orig 9-3 oil cooler assembly with hoses looks like this when removed from the car
http://www.stcf.net/OilCooler/images/16092007584.jpg
With the help of pliers and some force one can separate the engine side connector piece from the hoses
hoses intact:
http://www.npr.fi/~heikki/misc/oilcooler9-3b.jpg
separated:
http://www.stcf.net/OilCooler/images/16092007583.jpg
http://www.stcf.net/OilCooler/images/16092007585.jpg
The what you need is to have new hoses press-fitted into them.
http://www.stcf.net/viggen/hose_mod.jpg
http://www.stcf.net/viggen/hose_mod2.jpg
I'm sure one could pick up a pair (orig hoses) from a junk yard from which you can take the parts and then the only thing you need is to find a local hydraulics shop where they can press-fit the new hoses.
Other option si to utilize the NG900 "leg" which fits plug and play to 9-3, but it has threaded connection to the hoses
Thread size is M20 with 1.5mm pitch. Please note that the hole is not "threaded" all the way to the bottom and many pre-made nipples will "bottom-out" before seal surfcase meet.
One way to solve the matter is to shorten the nipple
http://www.npr.fi/~heikki/oilcooler/oilcooler-nipat.jpg
and to use copper seal for sealing
http://www.npr.fi/~heikki/oilcooler/...ler-nipat2.jpg
http://www.npr.fi/~heikki/oilcooler/...aikallaan1.jpg
http://www.stcf.net/OilCooler/images/18072007179.jpg
I can attest to using good oil lines and fittings, I tried to go the cheap route and had some issues with my oil lines leaking. I finally got smart and had some hoses made up at a hydraulic shop for about 35 bucks and they crimped the ends on for me. I feel much safer now.
John
1 - 7 of 7 Posts
