I just purchased a 1999 Saab 9 3. When the turbo spools completely it is into the red area of the boost gauge and the fuel cuts out. If anyone has any information on why this is happening I would greatly appreciate it.
That is a possibility, but the most common cause of overboost followed by a fuel cut on our cars is a clogged or failing BPC (Boost Pressure Control ) valve. In some cases, all you have to do is blow the crud out with shop air, or a can of compressed air.ParaMedic_Saab said:Sounds like a seized waste gate...
That is usually true, and it was, in my case.bchicoine said:...It is supposed to have base boost when the solenoid is disconnected...
This is how I have it isolated right now.PMI said:One way is to unplug the two hoses (Compressor and Wastegate) from the valve, and connect them together using a small 2-way hose connector you can get at any autopart store or hardware store.
Hmmm, sounds like the waste gate actuator and arm would be the next step. I think you can test that using a vacuum pump, the kind that can be set up to make pressure or vacuum, and check the base boost. I think you can get one from Autozone, loan tool program.bchicoine said:This is how I have it isolated right now.
Hate to say I told you so. Its becoming a very coming thing with our cars, according to my mechanic. Luckily its an easy fix.new93owner said:Well since my car still had its 3 month, 3000 mile warranty on it, I took it into the dealer and they had fixed it. They had told me that my waste gate acutator arm was seized so they took it out and cleaned it and greased it and now my car runs perfectly.
