Hi all,
I've been having a problem for about two months now and I'd like to ask You for some help.
My car: 9-3 2000my, b204E stage 2, apc 7 converted car
Each time I hit the pedal to the floor, around 3,5-4k rpm I'm getting overboost and fuel cut off. What I checked:
- It's not possible that apc is faulty, I replaced it to another t7 - the same thing
- I tried cleaning map sensor but it looked ok. Changing to another one, didn't help either.
- when connecting turbo directly to the wastegate I'm getting 0,5 bar of base boost, same thing after unplugging APC
- stage 2 program is set to hit max pressure at 1,35bar (I saw this in t5suite setup) but my readings showed that each time I'm getting cut off, boost is exceeding 1,55bar
- what's interesting - I had a another piece of Ecu from my cousin, bought in England (Maptun stage 1). When I swapped mine to it, the peak pressure was also ~0,2bar higher
than it's supposed to be (it was set to 1,15, and readings showed 1,35)
- in the end, someone suggested that I should unwind the actuator to go back to the stock base boost value. I did that, base boost is now 0,38bar, but max pressure hits 1,45
which is still way too high. There're also massive injection times - at peak boost ~31ms.. (According to simple tune-up stage 2, t5suite set it to 23-25ms at max).
Is it possible that wastegate spring is able to hold the flap and sustain 0,4bar base boost, but it's somehow weak or worn out and it's not releasing enough air to keep 1,35 at max load?
Maybe anyone has and idea, what might be causing this issue?
Please keep in mind that it's b204 so there's no MAF onboard.
thanks
charles
thanks
charles
