I have a 2007 9-3 where recently the radio would stop playing music/sound for a period of time and then randomly kick back on; all the while the head unit remained powered on. Same problem for CD's and AUX.
Important things to note
  • Blinker indicator noise still works
  • I know for 2007- and above they put the amp in the back trunk, and the blinker sound is stored in a different side panel.
  • A little research suggests fuses 25,3, and 14 could be at fault, but will check these a little later.
Any thoughts as to where I should begin, or if anyone had a similar issue? I have a feeling there's a loose wire in back of the head unit which I could take a look at as well.
Thx
Possibly the mute wire? I'm not sure what the mute signal is but if it's by grounding that pin at the head unit, it could be a short in that wire. The head unit (at least up through '06) generates all the notification sounds even when muted, so that would make sense.
