1 - 7 of 7 Posts
justinkennethlawley said:
hi ya,can you retro fit a later suspension to a 79 900 gls and is it a staight swop or are there any mods need
I don't know but I will move your thread to the old or classic 900 forum where they may be able to help.
Welcome to the boards btw.
Welcome to Saab central.
I was not aware of any change.
Please post pictures, there are no longer any 900s older than 1981 on here (I think).
Banned
I think the 900 series started in either 1978 or 1979. Seen quite a few of that vintage... they look quite similar to 99's but when you double-look you realise they've got the longer nose!
I guess you mean you want to fit the rear hand brake and 4x108 PCD hubs and the later calilpers and discs? All of those parts are available from the 1988-onwards 900.
It's quite a bit of work and ideally you would have the two cars sitting side-by-side so you could swap the parts over.
You need to change the following bits:
1. Handbrake mounting assembly between the front seats.
2. Fit handbrake cables going to the rear of the car.
3. Change complete rear axel (roughly 11 bolts)
4. Change inner-drivers on gearbox.
5. Change front hubs for later type.
On point 4... As the brakes were updated for 1988 so were the drive-cups on the sides of the gearbox. You will have to change the cups on the gearbox. This will mean you'll have to drain the gearbox oil and make sure you set the diff backlash properly as you install the later drivers. If you need the instructions anyone with a copy of the gearbox manual can help... just ask.
Be more specific about exactly what you want to use and what from. Many later bits will fit, some with more work than other.
I had a 79 gle 5-door (I still miss it) with a four speed. You can hang any 900 rear axle you want back there.
1 - 7 of 7 Posts
