I did a lot of research on this subject a while ago adn decided to do the work myself, although i still have to do the serp belt change. Do the work yourself, save some $$. Everything was VERY easy.
60k service needs.
Plugs NGK
Brake Pad Inspection
Check brake pads and discs: wear and condition
Interval: Every 15,000 miles.
Cabin Air Filter Replacement
Inspect exhaust system for loose or damaged components.
Engine Coolant Inspection
Check engine coolant freezing point and check for leakage
Engine Oil and Filter Change
Service will be determined by the service indicator
reminder on your SID display.
Tire Rotation
Rotate tires. Check tires for uneven wear or damage.
If irregular or premature wear is apparent, check wheel alignment
Battery Terminal Maintenance
Clean and grease battery terminals
Interval: Every 20,000 miles.
Airbag system, SRS warning lamp, Visual Inspection
Check/visual inspection airbag system, SRS warning lamp
Interval: Every 30,000 miles.
Brake System Inspection
Inspect brake hoses and brake lines
Drive Shaft Joint Boots Inspection
Inspect inner and outer drive shaft joint boots
Engine Air Cleaner Filter Replacement
Replace engine air cleaner filter.
Fuel System Inspection
Inspect fuel system for damage or leaks.
Suspension Joint Maintenance
Retighten front and rear suspension joint boots
Engine Drive Belt Replacement
Replace engine drive belt and check tensioner function
Interval: Every 60,000 miles.
Spark Plug Replacement
Change spark plugs
Transmission Maintenance
Change automatic transmission fluid
Interval: Every 90,000 miles.
