1 - 2 of 2 Posts
I tried to do a search for this, but the search kept timing out.
I have a check engine code on right now. When I turn it onto accessory, it blinks 6 times. What does this code mean?
I recently had the flex pipe before the cat replaced. The check engine light only came on after the flex pipe broke. The check engine light was off when I brought in the car to have the flex pipe done, then it came on shortly after, then off again, then on again...now it's been on for a few days.
I think I could try to reset the car by disconnecting the battery (works when the check engine light comes on due to using cruise control), but I want to be sure of what this code is first before I do anything else.
1 - 2 of 2 Posts
