im new to saabs &have a chance to get a nice turbo 1 for real cheap but the 5th gear syncro is toast. i wanted to find out how hard is it to change?
welcome to saab central :)
as for replacing the syncro on 5th its not at all difficult if you have the right tools, first you need to remove the wheel arch liner and then remove the gearbox mounting bolt, lift the engine so the box mount clears the the subframe then you can remove the 5th gear cover, remove the nut that holds 5th gear hub on and the pin or bolt that secures the fork them pull off the hub and replace the sincro ring and reasemble
