1 - 8 of 8 Posts
in your opinion would the 900 automatics have been better cars if they have been five speed.
Has anyone ever tried to swap?
Yes, I think that the autos would be better as a 5-speed, primarily because the auto tranny gearing seems a bit low for highway crusing and first gear seems a bit taller than it should be. The 5-speed would straighten that out for sure, especially on a turbocharged car because you could keep the engine in the high-output zone.
As far as swaps, I think that you're stuck with the Borg-Warner that came with the car. The C900 setup is unique and doesn't allow for much change.
ProfZ would be a good person to ask about the automatic transmission stuff.
you are lucky to have 3 speeds from a trans of that vintage! :lol: Gm was still using 2 speed "powerglides" when the B&W 3 speed auto was designed!
Yea, that is true but if the technology was available then, then would you consider it as an option to have this.
wife's got auto lpt conv, would be a lot better with 4th drive, had 3.6 jag xjs auto, 4th kicked in at about 50mph+ gave us 28mpg easy, the lpt auto does no better, also had 84, 900 4 speed when going 70 always felt i needed another gear as engine seemed to be revving hard(which i suppose it was, but no rev counter )mpg was 25-27 max . used to have triumph 2000's always had the electric 5th gear mpg miles better.
Yes, the autoboxes are low-geared. Remember, they were sold in the US market during the double-nickel days (boo, hiss:evil: ), when the national speed limit was 55 mph. SAAB probably figured the lower gearing would give crisper acceleration from rest, and top speed/high-speed cruising was irrelevant:p
I'd love even a 4-speed auto with lockup converter, but that's not an option for a Classic 900:cry:
The original automatic transmission, Oldsmobile's Hydra-Matic had 4 forward speeds. All Hydra-Matics had 4 speeds, until they developed the torque converter, (instead of a fluid coupling). The 1965 Turbo-HydraMatics (with torque converter) had 3 speeds because the torque conveter allowed for more flexibility and took the place of one of the speeds.
Only the Chevrolet Powerglide (tranny of choice for drag racers) had 2 speeds, a direct and a low... as well the Buick Dynaflow / Super Turbine 300 did, but the others didn't.
Auto tranny speeds are getting nuts nowadays, 7-speed Benzes and the like. Half the time you are accelerating you aren't because it's busy shifting :roll: 4 speeds is fine, 5 is better, 6 is probably optimum but once you start getting into 12 and 14 speed gearboxes as on a heavy truck it is a little stupid :roll:
1 - 8 of 8 Posts
