Attention 5Dr Owners: those pesky, flaky, decrepit stone rock guards gotcha down? These can be a particularly bad eyesore on lighter paint models and have always been a thorn in my side over the years. Recently discovered there to be a factory part number for the PPF (paint protection film) and it was on with removal.
OEM PN 4399754 LH and 4399747 RH
The small quarter trim piece is held on with two plugs at the bottom and a thin strip of double sided foam adhesive on top. I found it helpful to remove the forward plug retainer as well during install. The side skirt can be pulled back by removing the long rubber strip (full length of skirt behind both doors), one 10mm plastic nut in the wheel well and 2-3 10mm plastic nuts underside near jack cover. The old film came off with a heat gun, tough thumbnails, Goo Gone and A LOT of patience. I'd advise some more potent 3M Adhesive Remover if you can swing it to expedite the process. All cleaned, my paint was thankfully near perfect underneath. I hit the embedded dirt outline left behind with claybar and final prepped with alcohol wipes.
Installation: Peeled back and carefully positioned just the top rear corner of the film and mock laid the whole strip to follow the wheel arch evenly. Took my time, slowly worked my way down with just my thumb pad bit-by-bit. The film stretches/distorts so you don't won't to lift it back for air bubbles or put too much force or tension on it. Snail's pace prevented any bubbles for me. Took a few cool evenings to knock out but the results are well worth the effort and numb thumbs.
