Hi there,
I have a set of 315mm Brembos ready to go on my 9-5 when spring comes around and I can mount my newly-acquired 18" Turbo X wheels. I've searched all over this forum, and haven't found a definitive answer on whether or not 9-5s require spacers when running the Brembo setup. I see that the 9-3s need spacers (despite 9-3 wheels having an ET41 offset), but two things make me question whether the 9-5 will need spacers or not: 1) the stock Cobalt wheels appear to have an ET42 offset (thus being slightly further inside the wheel wells than 9-3 wheels) and 2) the 9-5 run ET49 wheels, including Hirsch wheels, making me think the hubs and rotors on the 9-5 are further recessed into the wheel well away from the mating surface than on the 9-3. Taliaferro's site for the 9-5 Brembo kit also claims these brakes will clear "most" 17" wheels, whatever that means (Taliaferro is notoriously scant on details and curt in their communications).
Can anyone definitively say if my ET41 Turbo X wheels will need a spacer to clear the fat Brembo calipers?
Second, will I be able to run 235/45/18 tires on my 9-5 without rub? That's another topic I've tried searching for on this forum. I'm currently running stock 2.3T suspension up front but plan on dropping to Aero ride height with Koni shocks within the next year or so. Tons of people are running 40-profile tires on 18-inch wheels on their 9-5s, but nobody appears to have explicitly addressed 45-profile tires. I assume if I do need a spacer, then I'd definitely want to run lower-profile tires, but I'm not positive.
Thanks!
Thanks!
