Is the shifter moving? When you step on the brake pedal, is the orange “brake” light on the shift console going out?
I'm not completely sure, the car is at the shop now so I can't check. He has it narrowed down to a input signal not talking back to the computer but aside from check every single in the vehicle it's guess work. My mechanic is super competent with Saabs but with that model/year the diagnostics just are not available so it comes down to the hours it takes to check every component to maybe find the issue. There's always more to the story
...Other issue that may be related or not...This started while I had been driving 30 mins 50mph just fine, I braked to turn on a side street and the car downshifted abruptly almost as if I was rear ended. As I continued the transmission would not shift out of low gear (automatic) I had about a mile to get home and aside from going slow I made it. No warning lights came on but I did notice the tach was not working. About an hour later I went out to start it and it did start but made all kinds of sputtering/rough idle and ever light on the dash was beeping and blinking at me! I quickly shut it off and called the tow truck. My mechanic diagnosed that the timing chain/guides etc. was broken...this looked like to problem but after all that was replaced and the engine started fine he knew this must have been a result of whatever the real issue was? He first checked out the computer by putting mine in another vehicle and it worked flawlessly so that's where I'm at today...how adventurous should I be with checking all signals/connections etc. or If somebody out their has experienced this problem they could just tell me it's the (XYZ) part and I'm up and running again. Any help would be appreciated.
This car has about 100,000 miles and to date has been running flawlessly.
