Ok I’m having an issue with my A/C the compressor went out so I replaced it, now the drive side is blowing out cold air and the passenger side is blowing out hot air ???
Do you get the same noise when you press the air recirculation button ( I think that is what it is called)?Ok when I put my new compressor in I had someone recharged the A/C but maybe they didn’t do it right or it leaked out
What do you think the clicking noise could be on the passenger side under the dash ? It starts clicking when I turn the air off and when I turn the air on it clicks for like 10 seconds then stops
There goes my idea about the noise.No just when I turn the air on or off
Follow up question, the compressor wasn’t engaging? Any idea if the clutch was bad or if you were low on freon? That would point us in the right directionIt wasn’t turning
I have a 2009 95 and have the exact same issue, had a very competent mech check it out and he ruled everything out so now we think it is a blend door issue which sucks for that is a pain and could be expensive. When the weather gets better I am going to take out the blower fan and run a scope down to see if I can find anything before I take the whole dash out. Let me know if you find anything [email protected]The clutch was bad I put Freon in the old compressor and the clutch didn’t engage that’s how I determined it was a bad compressor so I put the new compressor in, had someone re-charge it, now the clutch an everything is engaging it’s just blow out cold air on the driver side, and blowing out hot in the middle an the passenger side
