If your guessing machine works:
P1319 is not valid code.
Mimmi, thanks for reading and responding.If your guessing machine works:
Ok, yeah I just finished cleaning and testing the coils and the ionization module. Pulled the spark plugs and inspected. They looked clean and no fouling that I could notice.I still junk your guessing machine.
P1319 is not valid code at all.
I hope that you ordered original coils, aftermarket ones do not work.
What spark plugs you use and how old are they?
NGK PFR6D 10G as recommended on this board. The 13.. code is no longer pending so I canāt be sure it might have been 1312? That is a code that the board has attributed to coils in the past. I got my last set of coils used, per reference from Diggs. They worked fine for many miles but I donāt know how many miles are on them.What spark plugs you use (NGK....)?
If your coils are 320 000 km old, I consider changing them among spark plugs.
Thanks for your input.If the plugs have over 50k miles on them they are suspect. Factory interval was 60k miles I believe, but they often fail around 50k miles.
Pretty sure you were right about the plugs.If the plugs have over 50k miles on them they are suspect. Factory interval was 60k miles I believe, but they often fail around 50k miles.
