I have the navigation radio with the 6cd changer in the trunk.
After recently having the brake booster changed out and the battery
disconnected, where the clock would normally displayed in a button in the upper right corner of the display, it is now blank. If you press and hold this button, the clock set-up screen is pulled up. The problem is none of the adjustments are active or changeable and the clock display button is always blank. I have tried disconnecting the battery and rebooting the system with no success. I took it to my repair guy today and had him do a full scan which shows all the systems are communicating with each other and are happy, no error codes.
Has anyone ever come across this problem or have a solution for it? On a side note, I have never had a navigational cd for the system. Does anyone know of a source for one of these or would they be too out of date to be of any use?
Thanks,
John
Thanks,
John
