Hello there!
I have a problem with the wipers of my 9-3 TTid 'cause they work normally, arriving till the normal end of the glass when working, but when they are parked they stay in a position that is more or less 20 cm higher than it should be.
I've search also in the other posts about wipers but I haven't found something like this
Anyone had this problem?
Thank you!!
How long have they been this way?
Have they been removed ( replacing cabin air filter?)prior to seeing this problem?
Since 2 days.
I've notice that the resting position change if you use them but is always too high.
No I've just use them normally and suddenly they decide to do this
