When the car is off, any LED's will blink for about 5 minutes. They will also blink while driving, while the bulbs are turned "off". An example:
I put some 194 LED's in the city lights, the little bulbs that go in the high beam spot, under the actual high beam bulbs. When they were switched 'off' while driving, they would blink. When the whole car was turned off, they would blink for 5 minutes. I didn't care about the blinking when parked, but while driving that was unacceptable. They where borderline strobing, which is a great way to get in big trouble with the police, and/or confuse other road users. I've since put the incandescent bulbs back on there.
The car pulses each bulb on a regular basis to test them. If memory serves, it's PWM at work(pulsed width modulation). A low voltage signal is sent out to measure resistance. If the resistance is too high or low, it'll inform you a bulb is out via the SID. The voltage is low enough that it won't light up an incandescent bulb, but more than enough to briefly light up LED's.
EDIT : Mimmi beat me to it while I was typing, lol!
