1 - 9 of 9 Posts
any 2007 owners.
I notice when unlocking the car from the inside.
first push and the driver door unlocks
second push and the driver door locks and then all the doors unlock. does everybody's do this?
My 2003 does not unlock this way, and there is nothing in the manual about it.
also.
that super bright onstar light. I have to paint over it or something, BUT
is that supposed to stay on all the time, whether the car is running or not?
thanks
Yes my locks do the same thing.
platypus said:
any 2007 owners.
also.
thanks
My '03 and '07 did this. Probably your '03 was not programmed to do this. Also does it outside using key fob.
One thing my '03 did (not sure about '07) was if you unlock door with key fob, it would auto lock itsef after some amount of time. If I wanted to keep doors unlocked, I needed to unlock from within the car using door lock.
The Onstar light is probably bright when it receives an Onstar signal, letting you know it is active. I agree it is very bright!
I had my dealer set door lock to all open at once (from the remote).
This also happens with the inside switch.
So this appears to be something that can be configured with Tech II.
Mike
Mike
I'd like to get this done, too. Did your dealer charge you for the adjustment?
had mine changed in tech 2, also i have it set so when i go over a 10 mpg door lock, and then unlock after key out, then follow me home is set to 90 seconds ( i love my xenons so sexy!) :lol: and i also have it to if the a/c is on it turns it on recirculate when i use the mist on the wipers, so i dont smell the washer fluid. and all my doors unlock with one push on the fob or inside :D
I did not know this. You can have the doors UNLOCK when you take the key out? What's this called under Tech II?
Anyone have the link to ALL possible Tech II changes?
1 - 9 of 9 Posts
