Are the Miles stored in the pcm or cluster in an 06-08aero 9-5 saab. 1 is the aero version. Its to swap the running car from 145000 to 114000. How hard is this to do? the 08aero has a bad engine hole in the block
I haven’t done it myself but I’ve paid to have it done. I think once you get past all the dash trim, the cluster removal is straightforward. The miles are stored in the cluster. You’ll need a Tech II to marry the donor cluster to the running car.
Remember that you can only add miles to odometer. So use new MIU which have less miles than your car have.
